Old 01-03-2018, 04:26 PM   #1
miiser
miiser's Avatar
Drives: yaris 2009
How did you wire these leds ??
Do they open when u open the door?
miiser is offline   Reply With Quote
Old 01-03-2018, 06:58 PM   #2
Wired them to the pink and blue wires of the dome light connector behind the driver side chubby. I only wanted them to be on with the doors open.
Old 01-04-2018, 06:31 AM   #3
miiser
miiser's Avatar
Drives: yaris 2009
Damn sounds easy. I will add it to my todo list for the month ;)
If you have a picture of the wires that I have to use please post them :)
Old 01-04-2018, 07:19 AM   #4
It's pretty easy. I had a harder time finding a suitable spot on the passenger side for the board to go on (ended up going on the fan case itself).
Check out CTScott's post 14 here: http://www.yarisworld.com/forums/showthread.php?t=12220
You'll see the pink and blue wires.
Old 01-07-2018, 08:15 AM   #5
miiser
miiser's Avatar
Drives: yaris 2009
Thank you. I find the picture. One more thing. Where you bought the led stripe? eBay? And if yes do you have a link for it ?
Old 01-07-2018, 03:16 PM   #6
They're LED boards, not strips.
https://www.ebay.com/itm/10X-Festoon...item33b1d04a1c
Unless the seller changed the board, those should be the exact ones. I'm using those in the Yaris dome light, trunk light, and footwell lighting; as well as the dome and trunk light of my FR-S/GT86, and the trunk light of my brother's Prius c/Aqua.
Old 01-08-2018, 04:22 AM   #7
miiser
miiser's Avatar
Drives: yaris 2009
Finding Dory
And what about their life circle?? Do they burn easily??
I am looking right now for leds because I want to change all the stock yellow bulbs to white leds and so far I have read lots of bad reviews about the majority of them. I even saw reviews about melted boards What’s your experience?
Also I have an interesting question. If I replace the dome light with led bulb, the effect that the light closes slowly works? I don’t know how to describe, but when the light goes off, it goes slowly like it fades with the normal bulbs. I know it’s not that important but I do like it.
Finding Remote/Iginition Wire 2016 Hybrid drdyzio Third Gen Yaris General Discussion 1 11-14-2016 06:34 AM
Help finding part number joell DIY / Maintenance / Service 19 01-06-2015 03:41 PM
Need help finding the Japanese part number for the TRD Sway Bar (PTR11-52071) chalked Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 01-26-2013 03:29 PM
need a hand finding these spacers mr_miles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 12-11-2011 09:18 PM
I need help finding 17's for my ride Stoln Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-18-2009 08:21 AM
