#55 | |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Deng is certainly a good driver with a well setup car, he is on RE71R tires. |
#56 | ||
Radical Dreamer
Drives: off of T9 Join Date: Jun 2017
and I'm running 205/50 Dunlop Direzza Star Spec IIs at the moment. Thanks again guys, it means a lot coming from the both of you.
If you lack driver skill, add horsepower. |
#57 |
Data doesn't lie
oh.....oops lol
#58 |
Radical Dreamer
No worries, I wish I still had the re71rs. I killed them from not adjusting tire pressure, they were too high. :( the Star Specs were on sale, so I scooped them up.
And here's a picture that Caliphotography took.
#59 | |
Data doesn't lie
#60 |
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
Nice update man.
Glad to hear all is well for both you and the car after your off - pretty sure I'd need a fresh set of underoos after a spin that like at a nearly a buck sixty..! lol -- Adam |
#61 |
Radical Dreamer
Not much of an update.
Ever since owning the car, the driver's side rear toe has too much toe in, it's off in the .30* range while passenger side is around .15* I'm surprised the off at Big Willow didn't make it more out of spec. Rear: Toe L \ R .30 \ .15 Camber L \ R -.7 \ -.9 I'm experimenting with shims because the idea of using just washers doesn't sit well with me. At least with shims, there is more surface area for the hub assembly to make contact with the torsion beam assembly. These shims are cut out of .25mm shim stock. There are 6 pictured in the attach photo, but I only used 2 of these shims, and that was enough to kick the toe out from .30* to -.09*. I'm only using one shim now. I might have to pick up some .1mm shim stock and stack again. I really need an alignment rack in my garage. #torsionbeamwoes
#62 | |
I did a similar thing, just bought different gauge stainless and cut shims to set the toe to zero. http://www.smartracingproducts.com/
#63 |
Radical Dreamer
I've been debating about running 0 rear toe, but since it is my daily maybe a little toe in for highway stability.
![]() Either way, the smart string would be a good investment when I'm playing with shims. I feel it's going to be a steep learning curve for me initially. I figure once the bars are dialed in to the vehicle, future set ups will be a breeze.
#64 | |
Any time you use them on a new car for the first time it adds about 30 min just to dial in the bar setup, after that its easy. One of the best tools we ever bought.
#65 |
Radical Dreamer
Alright Jason, you talked me into running 0 toe all around, and I also ordered the smart strings lol. I have some stainless 0.05mm shim stock coming, so it's going to be like playing with razor blades!
#66 | |
Data doesn't lie
#67 |
Radical Dreamer
Best use of an 18mm and 23mm socket.
Front and rear toe set to 0.
#68 |
Data doesn't lie
Very Nice!
#69 |
Let me know what you think of the smart string, I may be interested in it down the road
#70 |
Radical Dreamer
Highly recommend the smart strings, I pretty much used it enough times to pay for itself.
Well, using the Yaris for HPDE has come to an end for now. I received my start date at my new job location in Michigan in August, so I'm going to be busy with relocation these next few months. Anywho, daily cross country spec. I tried going for that new school old school mash up, I like it. Enkei Compe 15x7 +38 195/55R15 Yokohama Avid Envigor Tsurikawa subway handle from my old drift car. I threw it on for fun. I think it looks pretty cool, but I'm not low enough for it to touch the ground. I'm going to remove my Cusco Coilovers this weekend and swap in the factory struts/shocks with the R*SR springs that I still have. It should be more comfy with a little rise in the ride height (sadly lol).
#71 |
Looks sharp sad to see you move to Michigan but its gonna be better living out there. I cant wait to leave the coast myself.
#72 |
Radical Dreamer
Yeah, I'm excited to move. I've been in SoCal all my life, so I'm looking forward to MI. I see it as an opportunity to live somewhere new.
Plus, no smog! Yaris is going to be the beater daily while I get another rwd sedan and 1j swap, yes!
| What is it about the Yaris | Ranger SVO | General Yaris / Vitz Discussion | 18 | 01-06-2015 09:45 PM |
| I wanna make my Yaris a Type S | beaker | Cosmetic Modifications (Exterior/Interior) | 2 | 10-06-2014 08:23 PM |
| DIY Cruise Control for 2012 European made Yaris | CTScott | DIY / Maintenance / Service | 1 | 12-27-2011 06:47 AM |
| Yaris T Sport UK Spec | Mrgreengenes | DIY / Maintenance / Service | 0 | 10-01-2009 11:16 AM |
