Old 01-17-2018, 09:38 PM   #1
400 dollar yaris
400 dollar yaris's Avatar
Drives: 2007 Yaris sedan
so about those rear sensors .....
well the lights are gone. no pictures really as it was a very straight forward fix for me. so being 10 degrees outside I decided to run up to harbor freight and get a few things before I freeze to death trying to do all four wheels. got a code reader and some electrical contact cleaner. after returning home, I hooked up the reader to see what I was dealing with. basically it was throwing codes for both rear sensors as well as one for debris on the right rear sensor and high or low voltage reading. so I just disconnected both sensors coated them in a good amount of contact cleaner and let it dry. next I carefully reconnected the sensors and cleared the old codes using the diagnostic reader. after turning on the car and taking it for a spin lights were off and no more codes so we will see if this did the trick. good luck to anyone experiencing this problem and I hope this post will help. from now on I will be checking wheel wells for excessive snow and ice in the mornings before leaving the house to help keep these areas clean. I suspect that there was dirt and snow/ice in the sensors causing them to fail. when it is warmer out, I may use some spray insulation on these sensors to hopefully avoid this issue for winters to come. as of now no lights on and I'm calling it a win. now if I can just find time to get these recalls done.....
400 dollar yaris is offline   Reply With Quote
Old 01-18-2018, 05:11 AM   #2
dogsridewith
Drives: 2007 2-door hatchback
Harbor Freight code reader Yaris Rear ABS brake sensors warning light dash
Happy for your fix and thanks for the great write-up. (Good use of an older thread.) I'd be interested in a part number or any description of that particular reader.
Did an earlier post in the thread mention reassembly w/ dielectric grease to protect connector contacts?
Old 01-18-2018, 10:32 PM   #3
400 dollar yaris
Yes it did which I will do as soon as its a little warmer and I don't have to lay in the snow as I am without a garage at my current apartment, but I believe the grease would definitely help to keep these exposed contacts safer. Also, the reader I got was from harbor freight, Zurich OBD2 ZR11 63807 it was a little expensive for me at 140 dollars but it seems like a very nice piece of equipment that will last me a long time. They had another one there for 190, but I chose to get the cheaper one. I highly recommend if you need one right away. Good luck to everyone with their cars and I'm glad to have found this thread.
Old 01-18-2018, 05:25 AM   #4
tmontague
tmontague's Avatar
Throwing in some dielectric grease in between both connectors would be a good idea next time you have the wheels off. Keeps the moisture out and will help avoid this issue again. Glad you were able to fix it
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
Trouble putting 3rd brake light after rear speaker install..... YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 5 12-05-2008 03:10 AM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Removing third brake light lightyearsgirl DIY / Maintenance / Service 8 08-06-2006 11:26 AM
