Old 01-17-2018, 09:38 PM   #28
400 dollar yaris
400 dollar yaris's Avatar
Drives: 2007 Yaris sedan
so about those rear sensors .....
well the lights are gone. no pictures really as it was a very straight forward fix for me. so being 10 degrees outside I decided to run up to harbor freight and get a few things before I freeze to death trying to do all four wheels. got a code reader and some electrical contact cleaner. after returning home, I hooked up the reader to see what I was dealing with. basically it was throwing codes for both rear sensors as well as one for debris on the right rear sensor and high or low voltage reading. so I just disconnected both sensors coated them in a good amount of contact cleaner and let it dry. next I carefully reconnected the sensors and cleared the old codes using the diagnostic reader. after turning on the car and taking it for a spin lights were off and no more codes so we will see if this did the trick. good luck to anyone experiencing this problem and I hope this post will help. from now on I will be checking wheel wells for excessive snow and ice in the mornings before leaving the house to help keep these areas clean. I suspect that there was dirt and snow/ice in the sensors causing them to fail. when it is warmer out, I may use some spray insulation on these sensors to hopefully avoid this issue for winters to come. as of now no lights on and I'm calling it a win. now if I can just find time to get these recalls done.....
400 dollar yaris is offline   Reply With Quote
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
Trouble putting 3rd brake light after rear speaker install..... YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 5 12-05-2008 03:10 AM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Removing third brake light lightyearsgirl DIY / Maintenance / Service 8 08-06-2006 11:26 AM
