Old 01-29-2018, 01:42 AM   #8
zoidberg444
zoidberg444's Avatar
I have a genuine Toyota one in my exhaust because the exhaust is OEM. I used an aftermarket one on my cousins car because it had a rusty aftermarket exhaust on.
If the fault was due to a loose petrol cap the car would probably set either:
P0442 - EVAP small leak detected
P0445 - EVAP large leak detected
Your codes seem to relate to circuit faults detected in the system. Could be anything from a bad solenoid valve, an actual circuit fault like bad wiring or corrosion in a wiring connector or a fault with the ECU.
Sent from my SM-G930F using Tapatalk
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles
UK to Nordkapp in a Yaris
My Echo Exhaust Leak in Front ? frank2005 General Yaris / Vitz Discussion 8 08-02-2017 09:52 PM
Red Angel Stop Leak - Need Advice Boba Ben DIY / Maintenance / Service 2 07-20-2017 10:36 PM
Yaris Hatch Leak Finally Fixed Yari$ DIY / Maintenance / Service 2 07-09-2017 10:43 PM
New question evap canister replacement Rutherford DIY / Maintenance / Service 3 02-06-2014 02:16 PM
