Old 02-05-2014, 02:07 PM   #1
Rutherford
Drives: 2008 Yaris
New question evap canister replacement
Ignore my old thread below as I have updated it.
Bought me a used evap canister and installed it. Thanks so much for the help with the connections. Was not difficult once I knew how to get them apart. After about 180 miles my check engine light came on and I went by Advanced Auto to see what code had come up. It read a small evap leak. I reset it and drove another 300 miles and the check engine came on again, same code P0456 small evap leak. I also still have a problem where I cannot pump gas very fast when I fill it up. It seems like it is not able to relieve the air as quick as I am putting the gas in. When I took the old evap canister off I checked the filter box? in the line from the evap canister to the filler neck. I did not remove it but I disconnected both lines leading into it and attached some tubing so I could blow through from each direction to make sure there was no water in it. I shook it and did not hear anything. Did not see any moisture but it seemed like there was some restriction in it. I figure it may only pass air/fumes in one direction but it was difficult to get air through either way. Could this cause the problem with not being able to pump gas at a normal rate or may I still have an issue with the evap canister? It did pass the emission test here in NC when the light was off.
Rutherford is offline   Reply With Quote
Need help with Evap Canister Replacement Rutherford DIY / Maintenance / Service 8 02-04-2014 10:59 AM
EVAP canister Jason@SportsCar Items for Sale by private party 5 04-11-2012 01:04 PM
Selling my Yaris - Clutch Replacement Question Swoleslaw DIY / Maintenance / Service 9 11-05-2011 11:27 AM
replacement bulb question justinparadise21 Cosmetic Modifications (Exterior/Interior) 2 11-06-2008 01:52 AM
