Old 01-31-2018, 11:41 PM   #1
Janviernes
Drives: 06 5door
Originally Posted by Ghastlyship View Post
Search for the diy of the horizontal to vertical wiper mod for rear wiper removal. It has pictures. Not sure about hose routing. Likely it’s routed over the roof upholstery.
Thanks, that helps some! :)
I'm hoping to locate the source of the hose in the engine bay so I can cut it off there and not have stagnant fluid in the line forever. But I'll check in the sills and pillars if that doesn't work out.
Janviernes is offline   Reply With Quote
Old 02-01-2018, 11:25 AM   #2
Ghastlyship
Drives: 2015 Toyota Yaris Hatchback
Best place to start looking would be the washer fluid reservoir, for obvious reasons. I don't think having stagnant fluid in the line would be an issue. It doesn't take much to flush it out and AFAIK it doesn't go bad like other fluids in cars.
What are you replacing the nozzle with? Are you deleting the rear wiper and washer nozzle?
Ghastlyship is offline   Reply With Quote
Inexpensive fix for low windshield washer fluid light stiuck on Toolaholic DIY / Maintenance / Service 5 04-21-2020 02:46 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Washer Fluid & Other Questions vaironl DIY / Maintenance / Service 1 11-16-2013 01:25 PM
Windshield washer fluid Twistoffate0817 General Yaris / Vitz Discussion 5 05-12-2010 12:47 PM
Washer fluid warning light "Backwards" Snyprwlf47 General Yaris / Vitz Discussion 2 02-15-2010 08:47 PM
