Thanks for the detailed description!
![]() My respect for doing this in -15 degrees Celsius. I would not do ANYTHING on my car in such conditions unless the risk of having unmovable car would be imminent. ![]() Actually - my radiator also has this pink/white crust on 2 places but as long as I do not need to fill anything in the reservoir I do not care. Well... once I started to think about changing the radiator (just to be sure) but that A/C radiator next to it scares me. I still cannot imagine how to take the engine radiator off without harming the A/C one, even with your DIY.
#2 | |
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
Solid DIY mate. Pretty easy job. It wouldn't worry me. Pulling the bumper off all the plastic clips and getting a hose on the petcock to make draining less messy and save your coolant is the hardest bit.
Its not all that detailed but i have a thread on the repair i did to mine here: http://www.yarisworld.com/forums/showthread.php?t=58345 The entire front end of the car was disassembled on that one.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
#3 | |
If I wasn't so meticulous of my car and didn't do track/autox days then I probably would have left the radiator for another couple years. It was leaking very very slowly and was never dripping onto the ground just staying on the rad and drying into a crust there. You're likely fine leaving yours but just keep an eye on it and the overflow reservoir. The Yaris's cooling system isn't sealed like some cars are so you do normally have a bit of evaporation every few months. The a/c condensor isn't anything to worry about just move it slowly and lift it off of the rad. The a/c lines allow some movement which is more than enough to remove the rad, you just need to be cautious. As Zoidberg stated, it isn't really that big of a job, it is just more involved than most cars that people are used to working on. If you look for the normal rad brackets that most cars have you won't see them and think it is super complicated.
#4 | |
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
for hardcore wrenching. lol-- Adam |
| yaris replace clockspring-remove airbag | stefan87 | DIY / Maintenance / Service | 11 | 11-19-2022 07:02 PM |
| HOW TO? Replace Yaris Antenna Hatchback | abdel.bolanos | DIY / Maintenance / Service | 6 | 07-11-2020 03:53 PM |
| Should I replace the motor mounts? | BennyLava | General Yaris / Vitz Discussion | 5 | 11-06-2017 08:32 AM |
| 2008 Yaris - replace key ignition with keyless (push button) start | jefflunt | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 11-20-2016 05:28 PM |
| Time to replace rotors. Which brake upgrades? | BennyLava | DIY / Maintenance / Service | 25 | 05-16-2016 05:57 PM |
