#1 | |
If I wasn't so meticulous of my car and didn't do track/autox days then I probably would have left the radiator for another couple years. It was leaking very very slowly and was never dripping onto the ground just staying on the rad and drying into a crust there. You're likely fine leaving yours but just keep an eye on it and the overflow reservoir. The Yaris's cooling system isn't sealed like some cars are so you do normally have a bit of evaporation every few months. The a/c condensor isn't anything to worry about just move it slowly and lift it off of the rad. The a/c lines allow some movement which is more than enough to remove the rad, you just need to be cautious. As Zoidberg stated, it isn't really that big of a job, it is just more involved than most cars that people are used to working on. If you look for the normal rad brackets that most cars have you won't see them and think it is super complicated.
#2 | |
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
for hardcore wrenching. lol-- Adam |
| yaris replace clockspring-remove airbag | stefan87 | DIY / Maintenance / Service | 11 | 11-19-2022 07:02 PM |
| HOW TO? Replace Yaris Antenna Hatchback | abdel.bolanos | DIY / Maintenance / Service | 6 | 07-11-2020 03:53 PM |
| Should I replace the motor mounts? | BennyLava | General Yaris / Vitz Discussion | 5 | 11-06-2017 08:32 AM |
| 2008 Yaris - replace key ignition with keyless (push button) start | jefflunt | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 11-20-2016 05:28 PM |
| Time to replace rotors. Which brake upgrades? | BennyLava | DIY / Maintenance / Service | 25 | 05-16-2016 05:57 PM |
