Old 03-06-2018, 08:55 PM   #1
Marchalis
Drives: Yaris yrs 2006
:Solved:
Lack of sleep over problem was the cause?
When I tested the fuel pump I tested the negative and positive as indicated on the pump.
It was a new pump that looked identical to the old. The plug that went into the pump only fit one way.
I can't say if I installed the pump with the plug somehow back to front or if the motor came in reverse, but changing the negative and positive on the top of the fuel pump unit in the car fixed the problem.
With direct connection with battery to the pump, it will make noise and run in reverse, but connected to the car it will not.
Marchalis is offline   Reply With Quote
electrical, fuel, fuelpump, problem., pump
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Fuel pump wiring help ATB DIY / Maintenance / Service 3 03-06-2018 01:06 AM
Which Fuse or Relay powers the Sedan's fuel pump? MUSKOKA800 DIY / Maintenance / Service 3 12-06-2015 11:38 AM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
