Old 12-05-2015, 05:58 PM   #1
MUSKOKA800
MUSKOKA800's Avatar
Which Fuse or Relay powers the Sedan's fuel pump?
For the life of me I cannot recall which fuse or relay we pulled to de-pressurize the fuel rail when we installed the S/C. The 1zz injectors cause a CEL (too rich, bank 1) during cold starts so I'd like to go back to the stock injectors for the winter. The manual makes no mention of which fuse powers the fuel pump. Many support EFI functions but those I pulled either killed the engine immediately or had no effect at idle. I recall after pulling a fuse it continued running about 10 seconds until low on fuel pressure and stalling.
Old 12-05-2015, 06:54 PM   #2
Did we actually pull a fuse? Can't remember myself.
Old 12-05-2015, 07:13 PM   #3
Pull EFI and crank the engine a few times. That's what I do when I need to open the fuel system. Have a small pan ready to catch what drips out when you pull of the flexible hose, as the system will not siphon that out.
Old 12-06-2015, 12:38 PM   #4
MUSKOKA800
MUSKOKA800's Avatar
Thanks Scott!
Yes Wee, I pulled most all of the fuses and also the three relays in the under-hood box. I know pulling one of them caused the engine to starve before we installed the Blitz.
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 326 02-15-2025 11:09 PM
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
help re wiring fuse box please kommodore DIY / Maintenance / Service 1 04-01-2014 03:11 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 04:20 PM
