Old 03-12-2018, 03:14 PM   #1
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
I've gone back and forth on this mod. Those that put their Yaris' to the test in real deal race environments claim that a good set of coilovers is all you need with this car. Those that drive on the street say it makes a yuge improvement. I tend to lean towards the guys who are beating these cars up on the track but I recognize that they're two different environments, so results may vary.
On Instagram
On Wheelwell
Old 03-12-2018, 03:16 PM   #2
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
Don't get me wrong, coilovers are on my list, but that's a good long ways away. For now, the sway bar is a great addition to my daily on the street. I'm right there with you though for sure.
m.flores.0928 is offline   Reply With Quote
Old 03-13-2018, 11:06 AM   #3
tmontague
tmontague's Avatar
I'll be posting my review about this once I drive around a bit on my coil overs (currently being made). I'd personally rather run no sway bar and proper suspension rates as the rear h beam is technically meant to be a semi independent system. The sway bar reduces this.
In a dd'r situation on stock or softer lowering springs this really is only a bonus to control the wander. However, on a track and higher spring rates it likely becomes a moot piece of metal.
I'll try and be as objective as possible when I compare both set ups to give some of you guys an idea of how the handling differs
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
2005 echo sway replacement sway bar meemadd Performance Modifications 7 08-15-2016 11:56 PM
xA or xD front sway bar fit in to 07 Yaris yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2012 09:47 PM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
