#1 | |
![]() Drives: Yaris Join Date: Mar 2018
Customized gauges
Coul you tell about how you removed the assembly from dashboard. I need to clean some blur behind the glass. Sent from my iPhone using Tapatalk |
#2 | |
![]() ![]() ![]() Drives: 2014 Yaris Join Date: Feb 2017
I'll get some more pics for you! Sorry for the delayed responses, I've been crazy busy Sent from my iPhone using Tapatalk |
#3 | |
Here are some pics. 1: pop off the outer trim piece with some sort of pry tool like a flat head screw driver. 2: unscrew the two bottom screws with a phillips head. 3: pop out the top portion gently. It's held in the some clips. 4: fish out the entire piece from between the dash and steering wheel. 5: the clear plastic piece is clipped in with 6 clips. The clips are clear plastic. 6: you can separate the main body portion too, just pop out out the bigger black plastic tabs. 7: when you disconnect the harness, you'll have to reset the clock. No big deal. However, I recommend keeping all gauge needles at bottom resting position when you reassemble it because I suspect them being offset if you reassemble it with the needles off resting position. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
#4 | |
Thanks for your effort. It is more complicated than I thought. I do not know if I can dare. Sent from my iPhone using Tapatalk |
#5 | |
It's way easier than you might think. I can get it disassembled to its individual parts in like 10 minutes without being very careful, honestly. It's made of plastic but it's pretty tough plastic. I'm not beating on it but I'm also not babying it. It's pretty easy! Sent from my iPhone using Tapatalk |
#6 | |
Also, I believe toyota sells just the clear plastic piece by itself. I think it has its own part number Sent from my iPhone using Tapatalk |
#7 | |
Customized gauges
Let me ask first Toyota service station. I was searching in all Toyota forums but could not find any info about dismantling this type of cluster. Thanks again... Sent from my iPhone using Tapatalk Last edited by some_0ne; 03-24-2018 at 05:56 AM. |
| Upper driver's side glove box w/ holes cut for gauges | PETERPOOP | Items for Sale by private party | 9 | 07-31-2011 07:21 PM |
| Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder | bieniman | DIY / Maintenance / Service | 4 | 05-19-2009 11:40 PM |
| My new gauges set up | PETERPOOP | Cosmetic Modifications (Exterior/Interior) | 30 | 04-19-2009 08:50 PM |
| Mechanical vs Electric Gauges? | PETERPOOP | Forced Induction Forum | 13 | 04-06-2009 01:25 AM |
| WTB: Boost Gauges | Teruyume | Items for Sale by private party | 4 | 11-12-2006 02:42 PM |
