you should be able to only turn it up but not down iirc. Keep turning it up and it should tighten. I honestly don't know why the Yaris drums are so bad at self adjusting, probably one of the reasons why most manufacturers went with discs in the rear.
I don't really find they even loosen, more that they don't adjust/tighten with reduction in shoe material. Although after a track day the e brake goes up a couple clicks which is likely due to the rear shoes wearing down a bit. If yours is actually getting loose then chances are the adjuster mechanism is installed incorrectly. On my sister in laws '07 yaris the e brake had to be constantly pulled really high to engage and still barely held the vehicle. Turned out one of her adjusters had a small piece installed the wrong way. Couldn't tell just by looking at it, only noticed it until i went to adjust it and it never tightened. Personally I find that my e brake holds my car really well, and that is really how it should work
#2 | |
![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
| rear hub spacers | tmontague | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 08-03-2015 10:42 PM |
| remove rear door's wondows | yarismo | DIY / Maintenance / Service | 1 | 05-11-2013 01:02 PM |
| Installing Rear Wheel Bearing Hub | brad4ds | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 07-22-2011 06:34 PM |
| installing Penguin Garage rear hub spacers! | Tamago | DIY / Maintenance / Service | 101 | 05-21-2011 12:29 PM |
