Old 07-31-2015, 09:24 AM   #1
rear hub spacers
Has anyone had any luck sourcing these now that MI is out?
I don't want to install wheel spacers but I like the hub spacers. If I can't find them anywhere is it a bad idea to just use washers and find longer hub bolts to essentially do the same thing?
Old 07-31-2015, 10:49 AM   #2
Rigaud
Drives: 2009 Yaris
Just use the right thickness wheel spacers. We use them with 500whp applications on Audi's. Really no issues especilly a Yaris and the rear too.
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 07-31-2015, 11:33 AM   #3
I don't like the idea of having 8 bolts instead of 4. I'm also not a fan of having the wheel too much further out from the bearing in regards to bearing life.
That's why I like the hub spacers so muc. No extra hardware other than longer screws.
Old 07-31-2015, 12:22 PM   #4
Rigaud
Drives: 2009 Yaris
For the distance you would use, it's a myth about stress and bearing life.
For a hub spacer, your idea of washers is not ideal since you wouldn't have full face contact and all the stress would be on the 4 bolts only.
Old 07-31-2015, 02:18 PM   #5
Good point about the washer idea. I just don't feel fully safe with wheel spacers. I plan on buying new rims. For my Yaris next summer so i'll likely just run a 35 offset and maybe more in the rear instead of running spacers.
Old 07-31-2015, 02:26 PM   #6
rear hub spacers
You don't need the wheel spacers that bolt to the hub and then bolt the wheel to the spacer. I've been running 10mm ichiba wheel spacers for a lot of years with no issue. Only had to replace stock studs with ones 10mm longer and good to go.
Old 07-31-2015, 07:21 PM   #7
Where'd you get the longer studs from?
Old 08-01-2015, 08:23 AM   #8
rear hub spacers
^ Napa. Somewhere on here I have posted the part# of the stud bolts I got from them. Search 'napa stud' and I believe you'll find the thread.
Old 08-01-2015, 09:47 AM   #9
Will do, thanks!
Old 08-03-2015, 10:42 PM   #10
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
have a set of hub spacers 10mm with bolts used that i got used but have not used...just lazy plus dont feel like getting new wheel bearings lol to do the job and yes u will need a set on a winter driven cars that have seen few winters .
They sit behind the hub just what ur looking for if interested .
Rear Hub Spacers Banana Man Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 02-27-2015 05:54 AM
Rear hub spacers Stiv Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 03-01-2010 11:54 AM
question on Rear Hub Spacers mastaofdisasta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-02-2010 09:54 AM
Penguin Garage Rear Hub Spacer Raffle!! Penguin Garage General Yaris / Vitz Discussion 27 06-30-2009 01:05 AM
