Old 03-27-2018, 06:54 AM   #1
miiser
miiser's Avatar
Drives: yaris 2009
The million dollar question. How to drive the wires into the door :p
miiser is offline   Reply With Quote
Old 03-28-2018, 02:35 AM   #2
B.B._07
Drives: 07 5dr
There's a couple options, you could get a new or used door wire harness that includes the wiring for the speaker from the dealer or a junkyard. Another option would be to re-pin the door wire harness connector at the B pillar (the other side of the connector shown in your photo) to add the two wires running to the door speaker. You can usually buy the pins with a short piece of wire attached at the dealer, or reuse them from an old connector. Re-pinning a connector is a bit more involved so you might want to read up on it or watch a couple videos before you try it. A final option would be to splice into the speaker wires at the B pillar, bypass the connector and run the two wires into the door beside the factory wiring. Either way you do it you will have to take the door panel off, unplug the connector in the photo and fish some wires though the rubber boot to the door.
Old 04-03-2018, 03:41 AM   #3
komichal
Obviously the two of us are trying to figure out the same thing.
I have given up my chances of tweaking the current wiring between the door and body.
I would probably drill a new hole through the body and the door, fit it with some soft, squeezable rubber hose, cut the wires from the connector, solder some additional connector and put extra wires through.
Currently I am looking for that rubber hose. :)
Wires for rear speakers komichal DIY / Maintenance / Service 20 11-09-2017 12:09 AM
Speakers wires : how to identify + and - ? hystria In Car Entertainment + Electronics (audio / video / alarm) 23 05-27-2017 10:43 PM
Replacing Speakers + Upgrading System ANONGMUSIC In Car Entertainment + Electronics (audio / video / alarm) 7 03-31-2012 05:45 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
No Sound Rear Speakers Help AutoXBot In Car Entertainment + Electronics (audio / video / alarm) 10 05-05-2011 03:41 AM
