Old 08-14-2007, 09:00 PM   #1
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
Speakers wires : how to identify + and - ?
Looking at those wires for the front door speakers, any idea which one is the + and which is the -
hystria is offline   Reply With Quote
Old 08-15-2007, 05:52 AM   #2
Razr
YRS WHOR
Razr's Avatar
Drives: White 2007 Yaris E-Limited 5dr
Simple trick actually..
1. Get a 9V "1N" type battery (the small rectangular general usage ones) and a connector to suit it with flying leads (bare wires). This shouldn't cost more than a few cents at an electronics shop.
2. Unscrew the OEM speaker and disconnect the factory wiring harness from it.
3. Momentarily "tap" the 9V battery leads across the speaker terminals. If the speaker cone moves forward when you do this, the + side of the battery is connected to the + speaker terminal. Likewise of the speaker cone moves backwards, the + of the battery is connected to the - speaker terminal.
4. Use your newfound polarity knowledge to work out which wire on the OEM adaptor is which :)
Note: don't use anything more powerful than the battery suggested, and only hold DC current on the speaker as long as you need to (i.e. < 1 second). An old, partially discharged 9V battery is the best bet - a fully charged one will get the cone hopping pretty hard. Lower voltage batteries will also work, but the cone movement may be too small to be useful.
Razr is offline   Reply With Quote
Old 08-15-2007, 07:56 AM   #3
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
One will probably have a black stripe on it and the other will be a solid color.
Old 08-15-2007, 06:10 PM   #4
uncleyaris
check out the factory manual, you can down load it!!
Old 08-15-2007, 06:43 PM   #5
hystria
hystria's Avatar
thanks
as for the battery trick, I don't have the connector anymore
Old 08-15-2007, 07:40 PM   #6
johnnyfive
johnnyfive's Avatar
a black stripe would imply a negative...usually, although the in-car wiring isnt always setup like that...could be any number of colors, could even be 2 compleatly different colors going to the same speaker.
what exactly are you trying to figure out?
what terminals are which on the factory speakers, or which wires are which in the factory wiring?
Old 08-15-2007, 08:57 PM   #7
hystria
hystria's Avatar
factory speakers have already been replaced last year, now I need to upgrade again but I'm not sure if the actual speakers are well connected and the OEM harness is gone... would be helpful to know which wire/color is what, yes
Old 08-16-2007, 12:07 AM   #8
Razr
YRS WHOR
Razr's Avatar
If you know one, you know the other - either way it's the same result
Old 09-04-2007, 01:14 AM   #9
cheukli
Drives: Toyota Yaris Liftback
it's very easy if you have a multimeter. Connect the wires of the meter to the speakers wires. if the meter display negative voltage, reverse the color of the connection. Therefore, the speaker wire connects to the red (positive) wire of the meter which is a positive output!
cheukli is offline   Reply With Quote
Old 09-04-2007, 04:06 AM   #10
Razr
YRS WHOR
Razr's Avatar
That would work for DC cheulki, but not for audio which is AC I'm afraid :(
Old 09-15-2007, 10:38 PM   #11
hystria
hystria's Avatar
that's the simplest way thanks
Old 12-15-2008, 02:57 PM   #12
tetzyamis
'09 5dr
tetzyamis's Avatar
Drives: 2009 Yaris 5-Door Bayou Blue
I'm just curious.
If, for any reason, the positive and the negative of the speaker wires are hooked up the wrong way, will the sound play so bad that anyone could tell something is wrong?
I just replaced the speakers this past weekend and just wondering that thinking it's installed incorrectly and I'm just not noticing it.
2009 5-Door Yaris LB Bayou Blue Pearl
2009 5-Door Yaris LB Black Sand Pearl
tetzyamis is offline   Reply With Quote
Old 12-15-2008, 03:07 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by tetzyamis View Post
I'm just curious.
no
Old 12-15-2008, 08:35 PM   #14
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
YEAH! 9v battery trick for teh WIN!!!!
Old 12-16-2008, 08:24 AM   #15
Actually, talnlnky, shouldn't you already have the wiring diagram for the radio harness??
someone had it posted on another forum, i didn't bother to save it and lazy to look for it right now.....
Old 12-16-2008, 02:27 PM   #16
tetzyamis
'09 5dr
tetzyamis's Avatar
AudioVisual.pdf of the Yaris repair manual have all information. From the exact color of the wires.
I was just wondering "what happens if positive and negative are hooked up the wrong way".
I did not mean I do not know which is positive and which is negative.
Old 12-17-2008, 12:25 AM   #17
Revsson
I think that if one speaker is hooked up the wrong way, you would have a
phase difference. One cone would move in while the other cone moved out.
I recall reading something like that years ago. So, I would assume the sound
wouldn't be as clean?
You could also do a search on the internet for wiring speakers and in phase
or out of phase issues, (I'm too lazy to do it now )
Of course, I would defer to the audio experts on here.
Old 12-17-2008, 06:24 PM   #18
i did flipped the + and - for one of my speakers.. the sound was weird. kinda like numb.
Is worth it to replace only front and rear speakers? tealio In Car Entertainment + Electronics (audio / video / alarm) 35 04-16-2010 09:11 PM
Call to those who adapted 6.5" speakers to rear of Liftback W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 9 03-10-2009 10:06 PM
Installing aftermarket componenet speakers and an amp in a LB grampi In Car Entertainment + Electronics (audio / video / alarm) 2 07-06-2007 07:49 AM
Component or coaxial speakers? eflb55 In Car Entertainment + Electronics (audio / video / alarm) 12 12-11-2006 09:40 PM
Matching up right speakers for 4DR Yaris.... ohms match up? ebowers83 In Car Entertainment + Electronics (audio / video / alarm) 7 09-13-2006 11:12 PM
