Old 04-28-2018, 10:17 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by TYaris2010 View Post
not sure where the step by step would be located on the site....
DISCLAIMER: The DIY below is for a hatchback. I haven't looked at a sedan at all, but I expect it's similar at least in terms of the cylinder.
Try this by member eepp:
http://www.yarisworld.com/forums/showthread.php?t=59514
Old 04-28-2018, 11:07 AM   #2
DISCLAIMER:I haven't looked at a sedan at all, but I expect it's similar at least in terms of the cylinder.
They are different in that the sedan does not have a thumb button.
Old 04-28-2018, 06:08 PM   #3
06YarisRS
Ah, I see. Thanks for clarifying that.
Old 04-28-2018, 10:45 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Usually the valet key will have a gray plastic head, while the normal key is black.
Door lock issue - new key or lock? RedSuns General Yaris / Vitz Discussion 17 11-01-2021 06:30 AM
Original OEM Toyota Yaris SEDAN 5 Piece Floor Mat Set! Including trunk mat! Sale!!! kmcherry21 Items for Sale by private party 3 01-29-2013 03:41 PM
