Old 04-28-2018, 08:39 AM   #7
TYaris2010
Drives: 2010 Yaris
My '06 and '08 (both older when purchased) had lock cylinders that would not turn due to contamination. It is not so big a job to take the lock mechanism out and clean it. There is a snap ring that is removed and the guts of the cyinder slides out. The one on my '08 was seized so well that I had to put the body of the cylinder in a vice and wiggle the shaft back and forth little by little until it was freed. I then took the guts out, flushed it a number of times with contact cleaner, until it ran clear. Then I lubricated it well, reassembled it and it's worked fine since. Every once in a while, I spray a bit of electronics cleaner in followed by a lubricant.
Another member posted step-by-step instructions with pics here on the site.
thanks, sounds like a potential plan. I was hoping to just spray something through the entry hole so I didn't have to dissemble it or, worst case, replace w/ a new cylinder with a different key. This car isn't that old, I'm guessing it froze to to not being used.
not sure where the step by step would be located on the site....
TYaris2010 is offline   Reply With Quote
Door lock issue - new key or lock? RedSuns General Yaris / Vitz Discussion 17 11-01-2021 06:30 AM
Original OEM Toyota Yaris SEDAN 5 Piece Floor Mat Set! Including trunk mat! Sale!!! kmcherry21 Items for Sale by private party 3 01-29-2013 03:41 PM
