#1 | |
#2 | |
![]() Drives: 2010 Yaris Join Date: Dec 2017
I pulled the lock- removing that carpet trim to get to it can be iffy....its supposed to 'look nice' so didnt' want to mar it up. Two 10mm nuts to remove the lock, pull the little c-clip thing to free it from the trunk safety actuator thing. Sprayed tons of PB Blaster directly into it....it still will not turn. Dunno whats up. Maybe this DID have a different key and dealer I got it used from (someone traded this in) didn't give them the key. I see OEM ones for $50-60 but yea then trunk has different key. It is important to have key access as the release lever by the drivers seat....they can fail, then you have no access to the trunk.... |
| Door lock issue - new key or lock? | RedSuns | General Yaris / Vitz Discussion | 17 | 11-01-2021 06:30 AM |
| Original OEM Toyota Yaris SEDAN 5 Piece Floor Mat Set! Including trunk mat! Sale!!! | kmcherry21 | Items for Sale by private party | 3 | 01-29-2013 03:41 PM |
