Spacers installed
I made a collossal screw up. After removing the drum to replaced the studs, I forgot to replace the drum and attempted to install the spacers directly to the wheel hub. Anyway, I had to machine lathe out a bit of the lip inside the spacer bore to make it fit I wasn't thinking. Bolted it all back together and went for a drive. It drove fine, but had an almost imperceptible bit of wheel wobble when looking at it in the mirror. Back to shop, realizing what I'd done and put the spacer outside this time. I hadn't removed enough material to make the hub bore loose. The other side, I did properly.
The studs went in easily with a bit of fiddling. On to the pics. Although they don't show the difference really well, in person it does look much better and more obvious. 3 new long studs installed. Rear brake job tomorrow. :) ![]() Top, before spacers, bottom after... ![]() Top, before spacers, bottom after... ![]()
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 04-30-2018 at 04:40 PM. |
#2 | |
| Wheel hub spacers be warned! | tmontague | Performance Modifications | 17 | 07-07-2016 09:56 PM |
| PG Hub spacers group buy | Vitz_Q8 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 45 | 11-15-2015 02:10 AM |
| FS: Hub Spacers (R) /Wheel Spacers (F). Come with extended bolts. | Betrivent | Items for Sale by private party | 1 | 06-26-2015 10:41 PM |
| Wheel spacers walkthrough :) | Lars | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 06-05-2014 08:49 AM |
| Installed 10mm PG spacers on a 15x7 +25 wheel | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-27-2009 07:10 PM |
