Old 04-30-2018, 04:26 PM   #6
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Spacers installed
I made a collossal screw up. After removing the drum to replaced the studs, I forgot to replace the drum and attempted to install the spacers directly to the wheel hub. Anyway, I had to machine lathe out a bit of the lip inside the spacer bore to make it fit I wasn't thinking. Bolted it all back together and went for a drive. It drove fine, but had an almost imperceptible bit of wheel wobble when looking at it in the mirror. Back to shop, realizing what I'd done and put the spacer outside this time. I hadn't removed enough material to make the hub bore loose. The other side, I did properly.
The studs went in easily with a bit of fiddling.
On to the pics. Although they don't show the difference really well, in person it does look much better and more obvious.
3 new long studs installed. Rear brake job tomorrow. :)
Top, before spacers, bottom after...
Wheel hub spacers be warned! tmontague Performance Modifications 17 07-07-2016 09:56 PM
PG Hub spacers group buy Vitz_Q8 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 45 11-15-2015 02:10 AM
FS: Hub Spacers (R) /Wheel Spacers (F). Come with extended bolts. Betrivent Items for Sale by private party 1 06-26-2015 10:41 PM
Wheel spacers walkthrough :) Lars Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 06-05-2014 08:49 AM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 07:10 PM
