2007 Generation 2 Toyota Yaris serpentine alternator belt tension squeal replacement
07 Yaris w/ AC serpentine belt. Examine the back of the belt w/ a strong flashlight. Particularly where it runs around the pulley that runs on the front of the belt. I'd clean up a new pulley w/ windex or something but never spray anything on the belt. Tighten if anything more than a chirp on the occasional cold start. Don't overtighten. Beware touching chain tensioner gizmo w/ prybar! Just replace the belt and then you have a spare...sorta inconvenient to be stuck along the road somewhere w/ you or no one able to just throw on a belt and get you going.
(2007 Generation 2 Toyota Yaris serpentine alternator belt tension squeal replacement) |
| Tags |
| alternator, belt, worn |
| Should I Change My Oil After 1300 Miles? | bronsin | DIY / Maintenance / Service | 3 | 10-28-2016 01:25 AM |
| Oil filter seeping oil from seal : Should I change it ? | Hershey | DIY / Maintenance / Service | 33 | 11-14-2012 04:25 PM |
| Oil Change Question... | jayeh | DIY / Maintenance / Service | 4 | 03-05-2012 11:15 PM |
| Help with oil change | trevor1980 | DIY / Maintenance / Service | 3 | 02-05-2012 10:46 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
