Old 05-18-2018, 06:11 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
We just replaced the front passenger side wheel bearing on an 09 Dodge Grand Caravan in our shop. The bearing was making a loud scraping sound, like dry metal on metal and increased with speed. We did all the typical tests, except for using a dial indicator for run out. There was absolutely no play at the 3 and 9 and 12 and 6 o'clock positions. A pry bar under the wheel yeilded absoultely no movement/shifting or play of any kind. In summary, everythng was as tight as could be. We replaced the bearing and the noise competely disappeared and the vehicle seemed 'tighter'.
I would be looking at the tie rod as you mentioned in your first post. Also, could the wheel have been bent or a tire belt blown after the median incident? That would definitely cause wobble. Did you spin the wheel when you had it jacked up?
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Wheel bearing or ??? shepd DIY / Maintenance / Service 11 08-10-2015 10:35 AM
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 07:38 PM
Yaris 2007 ABS & Brake light issue after wheel bearing change DevilzMafia DIY / Maintenance / Service 4 01-17-2013 09:24 PM
Front Wheel Bearing Failure craigq DIY / Maintenance / Service 4 08-17-2007 07:26 AM
