Originally Posted by mrpj
My Mk3 (U.K.), pre facelift, same as the o.p., has a plastic piece factory fitted to the driver's side only and much less obvious. Designed to do the same thing. I'll try to post a picture.
My car has that too, but that is more to counter the difference in wing mirror shape if im not mistaken. Newer models have a small vortex generator on the passenger side to counter the wiper blade air being channelled there. I put 2 on each side, one right by the base and further up the trim. I had to place the ome further up as it was a flatter surface to mount it. But if you look from behind the car the two are directly in the range of the wing mirror, and help disturb the air so it can pass around the problem area.
Sent from my SM-N910F using Tapatalk
