Old 11-09-2016, 09:47 AM   #1
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
problem generator
hi all . Need help descriptions of the contacts of the generator Yaris sedan 2007
The problem is , the alternator stopped charging the battery. The diode bridge is not damaged . Need check relay generator
I like very much travel
MickZEL is offline   Reply With Quote
Old 11-09-2016, 07:31 PM   #2
The diagram below shows the wiring.
Check the 7.5A ALT-S fuse, the 7.5A MET fuse and the 10A GAUGE fuse, as all three are required for the voltage regulator to work.
Old 11-11-2016, 05:43 AM   #3
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
what in the alternator may break if ripped power cable B
acceleration problem yaris 2012 sedan ahmedmhb Middle East 1 10-17-2013 04:32 AM
Help: dealer might not be able to fix window problem (2012 Yaris) matti Third Gen Yaris General Discussion 5 01-31-2013 10:37 PM
Car Race/IDLE/initial speed Problem mamun22s DIY / Maintenance / Service 0 08-28-2012 06:29 AM
Problem with electronic door lock new-yaris-owner In Car Entertainment + Electronics (audio / video / alarm) 7 08-05-2012 05:12 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
