![]() ![]() ![]() Drives: Yaris sedan Join Date: Apr 2011
problem generator
hi all . Need help descriptions of the contacts of the generator Yaris sedan 2007
The problem is , the alternator stopped charging the battery. The diode bridge is not damaged . Need check relay generator
I like very much travel |
#2 | |
Check the 7.5A ALT-S fuse, the 7.5A MET fuse and the 10A GAUGE fuse, as all three are required for the voltage regulator to work. Yaris - Charging.jpg
what in the alternator may break if ripped power cable B
| acceleration problem yaris 2012 sedan | ahmedmhb | Middle East | 1 | 10-17-2013 04:32 AM |
| Help: dealer might not be able to fix window problem (2012 Yaris) | matti | Third Gen Yaris General Discussion | 5 | 01-31-2013 10:37 PM |
| Car Race/IDLE/initial speed Problem | mamun22s | DIY / Maintenance / Service | 0 | 08-28-2012 06:29 AM |
| Problem with electronic door lock | new-yaris-owner | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 08-05-2012 05:12 PM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
