Old 05-21-2018, 12:03 PM   #1
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Originally Posted by Dliverance View Post
I got my 3D mats today. Hey fit great and look amazing but they interfere with my clutch pedal. My car wouldn’t start because the pedal wouldn’t go down enough to disengage the neutral safety switch. Anyone else have this problem?
Not at all. You obviously have the mat pushed as far back toward the rear of the vehicle as possible, right? Also, you're not placing the 3D mat over the factory carpet mats, are you?
On Instagram
On Wheelwell
Old 05-21-2018, 02:31 PM   #2
Dliverance
Drives: 2012 Black sand pearl <3
Its not over the original mat and I would imagine it’s in the proper place since the drivers mat has two locks that would locate it. I can get it to work but I REALLY have to press the pedal into the mat. I think I might have to trim the drivers mat.
Dliverance is offline   Reply With Quote
Old 05-21-2018, 02:50 PM   #3
Runethecursed
Drives: 2009 Yaris S
Pull up the carpet and cut out the foam under it... ;)
I put my wider pedals on and had the same issue with the clutch and the gas pedal till I did that... actually I removed the foam, but you get the idea
Runethecursed is offline   Reply With Quote
