Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
oh awesome when get some freeup time can i borrow your booth.
#2 | |
Same side as you man. I think Boston is about 6 - 7 hours to where we live.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 06-02-2018 at 07:32 PM. |
Dang right. After all this work, It would be sad to only paint one car in there. I do actually have a door ding to fix on my '08, so that will probably make an appearance in the booth too at some point.
...and even worse at pulling up a map ;)
BTW, it looks like no trip to NB for me this year. :( Will only be the 3rd out of 29 years not making the summer vacation trip to see the in-laws. Sent from my Elite_5_5_Octa using Tapatalk
#8 | |
Booth Lights Up and Running...
Got the lights up today and man, she's bright. I don't think I'll need any more. The wiring needs a little tidying up - a few wire staples here and there. I pieced the wiring together from ends I had lying around. A bit of overkill with 12/2 supplying the lights when 18 gauge would have been fine.
I built frames suspended from the ceiling so that the lights could be out of the booth. The ones mounted directly to the garage wall will be covered with the poly, Or -I haven't decided - I might build another wall and not use the actual garage wall at all. Please excuse the mess. ![]()
| DIY: Painting Engine Cover | frownonfun | DIY / Maintenance / Service | 12 | 11-30-2013 11:07 PM |
| Stripping Paint Without Sanding | CrystalJean | DIY / Maintenance / Service | 1 | 10-06-2012 04:06 PM |
| Advice on paint booth | CAyaris | DIY / Maintenance / Service | 12 | 02-11-2011 09:37 AM |
| New 2007 Paint Condition | Pavel Olavich | DIY / Maintenance / Service | 16 | 09-13-2009 04:14 PM |
