...and even worse at pulling up a map ;)
BTW, it looks like no trip to NB for me this year. :( Will only be the 3rd out of 29 years not making the summer vacation trip to see the in-laws. Sent from my Elite_5_5_Octa using Tapatalk
#2 | |
Booth Lights Up and Running...
Got the lights up today and man, she's bright. I don't think I'll need any more. The wiring needs a little tidying up - a few wire staples here and there. I pieced the wiring together from ends I had lying around. A bit of overkill with 12/2 supplying the lights when 18 gauge would have been fine.
I built frames suspended from the ceiling so that the lights could be out of the booth. The ones mounted directly to the garage wall will be covered with the poly, Or -I haven't decided - I might build another wall and not use the actual garage wall at all. Please excuse the mess. ![]()
| DIY: Painting Engine Cover | frownonfun | DIY / Maintenance / Service | 12 | 11-30-2013 11:07 PM |
| Stripping Paint Without Sanding | CrystalJean | DIY / Maintenance / Service | 1 | 10-06-2012 04:06 PM |
| Advice on paint booth | CAyaris | DIY / Maintenance / Service | 12 | 02-11-2011 09:37 AM |
| New 2007 Paint Condition | Pavel Olavich | DIY / Maintenance / Service | 16 | 09-13-2009 04:14 PM |
