Old 05-29-2018, 10:10 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by DarkShadowFox View Post
oh awesome when get some freeup time can i borrow your booth.
Of course!
Old 06-02-2018, 09:46 AM   #2
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
Of course!
yaaay now to get to new brunswick. :X which side of canada is that on im bad with my provinces
DarkShadowFox is offline   Reply With Quote
Old 06-02-2018, 03:55 PM   #3
06YarisRS
Same side as you man. I think Boston is about 6 - 7 hours to where we live.
Old 06-03-2018, 01:01 PM   #4
DarkShadowFox
time to breakout my passport.
Old 06-03-2018, 03:47 PM   #5
06YarisRS
Dang right. After all this work, It would be sad to only paint one car in there. I do actually have a door ding to fix on my '08, so that will probably make an appearance in the booth too at some point.
Old 06-02-2018, 05:00 PM   #6
...and even worse at pulling up a map ;)
BTW, it looks like no trip to NB for me this year. :(
Will only be the 3rd out of 29 years not making the summer vacation trip to see the in-laws.
Old 06-02-2018, 07:34 PM   #7
06YarisRS
That's too bad WeeYari. There's always next year, and the year after and...
Old 06-02-2018, 07:45 PM   #8
06YarisRS
Booth Lights Up and Running...
Got the lights up today and man, she's bright. I don't think I'll need any more. The wiring needs a little tidying up - a few wire staples here and there. I pieced the wiring together from ends I had lying around. A bit of overkill with 12/2 supplying the lights when 18 gauge would have been fine.
I built frames suspended from the ceiling so that the lights could be out of the booth. The ones mounted directly to the garage wall will be covered with the poly, Or -I haven't decided - I might build another wall and not use the actual garage wall at all.
Please excuse the mess.
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Stripping Paint Without Sanding CrystalJean DIY / Maintenance / Service 1 10-06-2012 04:06 PM
Advice on paint booth CAyaris DIY / Maintenance / Service 12 02-11-2011 09:37 AM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
