![]() Drives: 2008 Yaris Join Date: Feb 2018
you could see if this guys squeaky belt solution works for you...
https://www.youtube.com/watch?v=HRrVMtyIqIY |
#2 | |
![]() ![]() ![]() Drives: Yaris manufactured after 2007 Join Date: Nov 2010
R. |
#3 | |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
I wouldn't be overly concerned with the belt being to tight. I've changed the serpentine belt on a Toyota 1.8L 1ZZ engine which is the big sister 1.5L 1NZ in the Yaris. The 1ZZ has an auto tensioner and it puts a lot of tension of the belt. If you're super concerned about the tension being too high you can loosen the tension to the point that it starts to squeak and mark that point on the tension adjuster with a paint pen/whiteout/nail polish/scratch awl/etc. Then tighten it a little bit, mark the point, and test it and repeat until the squeaking goes away. I used that method and my belt is nice and quiet. |
![]() ![]() Drives: 2015 Yaris L Join Date: Jun 2017
Yep, best way to do it right there B.B.
A Yaris belt is so easy to tighten that it only takes a few tries to get it right if you have an ornery belt. |
| Tags |
| belt, determining, proper, tension |
| Which serpentine belt? | courtartanis | DIY / Maintenance / Service | 0 | 11-30-2017 11:32 AM |
| Yaris serpentine belt!!! | Ramon1691 | DIY / Maintenance / Service | 9 | 04-11-2016 12:00 PM |
| Serpentine Belt Replacement - Is it possible to get it too tight? | keith204 | DIY / Maintenance / Service | 5 | 05-25-2015 05:52 AM |
| Squeal from Engine after replacing Water Pump and Serpentine Belt | vidfan | DIY / Maintenance / Service | 7 | 06-24-2014 11:41 AM |
| Lost Serpentine Belt | NickNickNick | DIY / Maintenance / Service | 33 | 07-31-2011 01:28 PM |
