Old 11-30-2017, 10:32 AM   #1
courtartanis
Drives: Yaris 2005 1.3 - P2 facelift
Which serpentine belt?
Hi,
My engine has only a single drive (serpentine) belt that needs replacement. It's the 2SZ-FE engine with AC, and currently has a Toyota OEM 6PK1770 belt.
However, when I try to locate the correct drive belt on EuroCarParts, I only get two drive belts listed for my engine.
6PK1765, or 6PK1775 - Will that 5mm either way make much of a difference on these engines or should I try to hunt elsewhere for the OEM 1770mm belt?
Thanks
EDIT: I've found a solution, the Gates 6PK1768 is the non-OEM branded equivalent to Toyota part number 90080-91223 (also manufactured by Gates) - not sure why they felt the need to add 2mm to the print.
courtartanis is offline   Reply With Quote
2sz-fe, belt, drive, serpentine, squealing
Yaris serpentine belt!!! Ramon1691 DIY / Maintenance / Service 9 04-11-2016 11:00 AM
Squeal from Engine after replacing Water Pump and Serpentine Belt vidfan DIY / Maintenance / Service 7 06-24-2014 10:41 AM
new serpentine belt dferguson2 DIY / Maintenance / Service 1 06-30-2012 08:07 PM
Lost Serpentine Belt NickNickNick DIY / Maintenance / Service 33 07-31-2011 12:28 PM
serpentine belt for 2007 yaris hatchback nikki9 DIY / Maintenance / Service 4 04-09-2011 09:22 AM
