Tip: Tighten the bleeder nipples a touch until you just feel them move, or hear a crack, before trying to loosen. This works well on bleeders especially because even if you break one, you know it's still tight and not going to leak. Bolts/bleeders are much stronger on tension (tightening) so they are less likely to break.
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 10:42 AM |
| Aftermarket Clutch Q's | tmontague | Performance Modifications | 5 | 03-05-2016 04:33 PM |
| Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 08:05 AM |
| Question on brake bleeding... | Yarflana | DIY / Maintenance / Service | 6 | 04-03-2013 01:55 PM |
