#1 | |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
Proper way to adjust the rear drums is to keep increasing tension untill the wheel begins to drag when you try to spin it with the drum on and the parking brake off. |
#2 | |
![]() ![]() Drives: 07 Yaris Liftback Join Date: Nov 2010
#3 | ||
#4 | |
That's exactly what my issue is. I think adjusting them now Also I have the disc rear axle beam part number if anyone cares... I want disc rears just cause haha |
![]() ![]() ![]() Drives: 1987 Silverado Join Date: Jan 2010
A late update:
I adjusted the rear brakes manually, and it fixed the problem. They have returned to their previous feel. Also took the time to clear coat the shiny metal drums. Hopefully that clear will hold up over the long term against the rusty look. |
| Mysterious Brake Fluid Loss | xdarkxfirex | DIY / Maintenance / Service | 5 | 09-30-2017 09:18 PM |
| 98k mile A/T fluid change and it's wierd?!? | 07stlYaris | DIY / Maintenance / Service | 6 | 10-11-2014 02:38 PM |
| Should I change my brake fluid? | lh59 | DIY / Maintenance / Service | 4 | 06-27-2012 12:48 AM |
| Brake lines/brake fluid change out | jstantherprsn | DIY / Maintenance / Service | 3 | 11-02-2010 12:53 PM |
| Anyone have their brake pedal go rock hard on hot days? | LtNoogie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 07-28-2009 12:20 PM |
