Old 06-16-2018, 09:28 PM   #16
B.B._07
Drives: 07 5dr
Originally Posted by DarkShadowFox View Post
yyou could upgrade to discs and save yourself the headache of drums/
A rear disc upgrade is a lot of work and a good chunk of change even with junkyard parts for very little (if any) reward in a small and light car like the Yaris. Not to mention the lower maintenance, parts costs and much longer lifespan of rear drums over discs.
Proper way to adjust the rear drums is to keep increasing tension untill the wheel begins to drag when you try to spin it with the drum on and the parking brake off.
Mysterious Brake Fluid Loss xdarkxfirex DIY / Maintenance / Service 5 09-30-2017 09:18 PM
98k mile A/T fluid change and it's wierd?!? 07stlYaris DIY / Maintenance / Service 6 10-11-2014 02:38 PM
Should I change my brake fluid? lh59 DIY / Maintenance / Service 4 06-27-2012 12:48 AM
Brake lines/brake fluid change out jstantherprsn DIY / Maintenance / Service 3 11-02-2010 12:53 PM
Anyone have their brake pedal go rock hard on hot days? LtNoogie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 07-28-2009 12:20 PM
