Old 06-15-2018, 08:09 PM   #11
BennyLava
Drives: 1987 Silverado
Originally Posted by tmontague View Post
15 clicks is way too many, it means you need to adjust your star adjuster to tighten the shoes to the drum. This is why your brake pad feels soft. That causes this effect on the Yaris
Thanks, I'll do it. How many clicks would it be if things were normal?
And I do have to ask the question: I thought they were supposed to be "self adujusting". As in, they'd finally adjust themselves even if it took awhile. Maybe the self adjusting part only works within a certain limited range?
BennyLava is offline   Reply With Quote
Mysterious Brake Fluid Loss xdarkxfirex DIY / Maintenance / Service 5 09-30-2017 09:18 PM
98k mile A/T fluid change and it's wierd?!? 07stlYaris DIY / Maintenance / Service 6 10-11-2014 02:38 PM
Should I change my brake fluid? lh59 DIY / Maintenance / Service 4 06-27-2012 12:48 AM
Brake lines/brake fluid change out jstantherprsn DIY / Maintenance / Service 3 11-02-2010 12:53 PM
Anyone have their brake pedal go rock hard on hot days? LtNoogie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 07-28-2009 12:20 PM
