Old 06-27-2018, 09:05 PM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
hell yeah nice purchase. My clutch started going soft at 120k...however I do beat it up on the regular & I upgraded to a higher capacity ACT unit
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-01-2018, 01:07 AM   #2
40mpg
Drives: 2009 Yaris
How was the install? I've done a couple Honda's. I assume it would be a little tougher with the Yaris being a smaller car. I'm very mechanically inclined, however extremely busy. I would have to do it in one day. Possible?
Sent from my SM-S327VL using Tapatalk
2009 Yaris Sedan-Power Package 5 speed
40mpg is offline   Reply With Quote
Old 07-01-2018, 03:02 AM   #3
zoidberg444
zoidberg444's Avatar
I did it in a few hours on my 1.0 hatchback. I thought it was pretty easy. Only major hiccups were the lower ball joints being seized in the control arms. I had to take the upper bolts out that pinch the strut to the knuckle. Meaning i had to get the tracking adjusted afterwards.
The rear engine mount. Specifically the through bolt into the subframe was a BITCH. Impact wouldn't shift it. A meter breaker bar with a cheater backwards and forwards and lots of homebrew penetrating fluid.
I'm sure the engine bay is a little tighter with a 1.5 4 cylinder than a 1.0 3 cylinder so getting the gearbox in and out would probably be a little more troublesome.
Depending on where you live, you might be one of those lucky people where the cars don't rust and hand tools will do everything.
Sent from my SM-G930F using Tapatalk
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles
UK to Nordkapp in a Yaris
Old 07-13-2018, 01:57 AM   #4
m456an
m456an's Avatar
Drives: Yaris 2005 petrol
Well done, I struggled with the rear wiper nut and gave up. It seemed to be welded on.
Roads of roads,
Like cars of hope -
Gas and air mix like explosions of exhaustion.
m456an is offline   Reply With Quote
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
