![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
ebrake only working on passenger side
I know I need new cable/s but I pull the lever up with full force and it only locks the pass side.It doesnt even grab the brake drum period.Anything to look at that I can do myself?
I will be ordering a cable and having a shop change it but for know I want both tires to lock if possible. P.S adjusted star and pads are really close to drum. |
Nothing to look at really unless you were going to replace the cable yourself. Quick tip, if the 10mm bolts are seized that hold the e brake cable to the body just use zip ties. I had to do that on my old echo as all the 10mm bolts snapped off and I couldn't remove them w/ easy outs and zip ties worked great.
chances are your e brake driver side cable it seized due to lack of use. Once those things seize there is no getting them to un seize
Or keep it that way for super sweet e brake 180s for running shine down the 405 before ol smokey catches you..
#4 | |
Prefer to buy within canada if possible. |
Check online, auto parts way is Canadian but I typically stick w/ ebay or rock auto so I'm not much help if you want to stick w/ Canadian. Dealership price for the cable is darn expensive iirc
#6 | |
Thanks for the help btw. |
I wouldn't mess w/ the cables till you have the new parts. It sucks trying to get drums off w/ a stuck e-brake cable.
#8 | |
I found out the one side was not engaging by being able to remove drum with ebrake engaged. I realized ebrake was on(Good side) once I got to the other side and the drum would not come off. |
sometimes best to get it apart before ordering any parts...expected bad part may not be the problem and/or other parts are also required. (what's going on at the other end of that cable? noting I know nothing about these cables on Yaris...how one lever pulls two cables, etc.)
#10 | |
Adjusted star untill slight grab drum.Adjustment thingy uner console is maxed out. Only thing it cam be is stretched cable with one side broken or seized. P.S I hate drums with a passion.My next car will have discs allround mandatory. |
brake rust disc drum
discs and their calipers/sliders rust worse/quicker than drums w/ their cylinders and shoes. and 2 or 4 wheeled vehicles rust worse towards the rear due to spray back from the front tire(s)
discs rust just from being so exposed to dew, etc. which repeatedly re-activates the calcium chloride in the rust pits. |
#12 | |
Fixed!
| Passenger side caliper loose... | baseballfan416 | DIY / Maintenance / Service | 5 | 08-17-2016 11:35 PM |
| Replace 2008 Yaris D4 sedan passenger side window | harvey | DIY / Maintenance / Service | 0 | 08-01-2015 03:53 PM |
| Enginge bay rattle on passenger side - advice | aliasofmike | DIY / Maintenance / Service | 11 | 02-26-2012 01:00 PM |
| Wet floor on the passenger side? Got it! | nemobile | DIY / Maintenance / Service | 8 | 01-20-2012 01:57 PM |
| Noise on the passenger side with audio | zachryboles | DIY / Maintenance / Service | 1 | 10-19-2011 09:32 PM |
