Old 07-20-2018, 06:57 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by Kalispel View Post
With pure direct-inject engine designs (like Mazda uses - and most other automakers for that matter), even top-tier gas will only address HALF the carbon buildup/deposit problem. They are simply flawed engine designs from a reliable, problem-free consumer ownership standpoint. Direct injection needs to be paired with port-injection to address the whole issue adequately, with regards to top-tier fuel detergents keeping carbon deposits at bay across BOTH problem areas. Toyota was smart enough to do just that with their new TNGA 2019 Corolla engine design. That's also another reason to LOVE the venerable non-direct-injection 1NZ-FE engine still being used in the Yaris.
An oil catch can should keep the intake valve pretty clean.
Sent from my SM-G930W8 using Tapatalk
Old 07-21-2018, 12:49 PM   #2
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
Shouldn't Mazda (& others) be doing that from a design & factory-build standpoint? It should be standard equipment for straight GDI engine designs, if they care anything about building a reliable, trouble-free engine that stands the test of time.
Kalispel is offline   Reply With Quote
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
