Old 07-27-2018, 06:41 AM   #1
Pinchlite
Drives: 2007 yaris HB
Fixed!
Originally Posted by tmontague View Post
Nothing to look at really unless you were going to replace the cable yourself. Quick tip, if the 10mm bolts are seized that hold the e brake cable to the body just use zip ties. I had to do that on my old echo as all the 10mm bolts snapped off and I couldn't remove them w/ easy outs and zip ties worked great.
chances are your e brake driver side cable it seized due to lack of use. Once those things seize there is no getting them to un seize
The device where the 2 cables connect to the single cable that connects to handle is inside.Easy peasy.Silver Heat shield had to be removed but all went real smooth.Ebrake works tiptop know.The Dorman cables that I got off ebay for $66.00 CAD EA or so fit perfectly.
Passenger side caliper loose... baseballfan416 DIY / Maintenance / Service 5 08-17-2016 11:35 PM
Replace 2008 Yaris D4 sedan passenger side window harvey DIY / Maintenance / Service 0 08-01-2015 03:53 PM
Enginge bay rattle on passenger side - advice aliasofmike DIY / Maintenance / Service 11 02-26-2012 01:00 PM
Wet floor on the passenger side? Got it! nemobile DIY / Maintenance / Service 8 01-20-2012 01:57 PM
Noise on the passenger side with audio zachryboles DIY / Maintenance / Service 1 10-19-2011 09:32 PM
