Old 07-27-2018, 07:37 PM   #1
Runethecursed
Drives: 2009 Yaris S
Originally Posted by Fluxtasy View Post
I did give it some thought, as safety is a concern so wouldn't it be better to swap the entire axle?
2200lb car with some dinky rear disc brakes. Id trust any competent welder for that.. hell we got guys with full custom set ups doing the king of the hammers challenges
XD
Runethecursed is offline   Reply With Quote
Old 07-29-2018, 08:10 AM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
XD
dinky huh. you do know that the rears are larger in diameter than non rs brakes, with no ventilation lol.
Old 07-29-2018, 11:15 AM   #3
Runethecursed
Dink in comparison to a normal sized cars rotors, and yes the disc rears would be bigger than a non rs brake rotor.... if I were running that. I'm running Matrix front brakes right now per the swap guide. the rears are still dinky
Old 07-29-2018, 11:21 AM   #4
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
rears are dinky even on the GRMN, its a FWD car most of your stopping power is upfront. its why the front caliper is like 10.5 and the rear is 9. something. its not like your running 600 HP and need 320 MM BREMBO 6 PISTON breaks, so the rears on a stock tuned car are fine.
suggestion because people have told me in the past, better pads. when those shit the bin, better calipers and brakes.
DarkShadowFox is offline   Reply With Quote
Tags
disc, disc conversion, drum
Possible DIY rear disc conversion brushforhire Wheels, Tires and Suspension Forum sponsored by The Tire Rack 25 01-22-2024 03:36 PM
Need rear brake help! Star wheel/spring combo won't reattach msapocalypse DIY / Maintenance / Service 0 10-08-2016 06:19 PM
Yaris Rear Driving Lights Problem ap222 DIY / Maintenance / Service 3 05-31-2013 05:49 PM
drum brake conversion to disc brake bogartvitz Performance Modifications 8 04-15-2013 10:21 PM
