#1 |
Bogart
Drives: Vitz 2010 Join Date: Apr 2013
Hi! I'm from Manila, Philippines. I would like to ask and question how this things can be possible done here in manila.
Speaking of MI, i really wanna order complete brake for my yaris (I saw in other thread) but it will cost me a lot :( - Is the vios/ yaris sedan will match the rear disc brake on my yaris hatch? i saw a lot in japan surplus here in manila. but i am afraid maybe there will be a problem. - how about the ABS sensor? would still be intact on my yaris? - you have any idead if i am getting a slotted rear disc, what things should i need? I hope to hear from you soon guys! Thank you very much. More power to Yarisworld! |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
Not sure about the Yaris, but I looked into a rear disk conversion and it just doesn't seem worth it for now..
Looks to be about $950 unless u can find cheaper donor parts at a junk yard Parts List: Bendix Ceramic Pads #8085-05016842 set $30.10 A1 Cardone #8085-07048183 Rear Left $48.10 A1 Cardone #8085-07001621 Rear Right $48.10 Caliper mounting bolts – OEM, #47715-01010, (2 @ $6.10 ea.), #47715-01020, (2 @ $6.79 ea.) Standard Rotor Centric #8085-05116108 (2 @ $18.60) or Vented Rotor Centric StopTech Rear Left #8085-05132227 Rear Right #8085-05132228 (2 @ $68.10) Parts Master Wheel Hub Assembly w/ ABS #8085-07062329 (2 @ $54.10) Toyota OEM Dust Cover and Backing Assembly #46503-20070 and #46504-20070 (2 @ $180) Rear axle hub retaining bolts – M10-1.25, 35mm flange bolts, (8 @ $2.00) Raybestos PG Plus parking brake shoes, #796PG, $41.99 Parking brake shoe struts – OEM, #47613-32030, (2 @ $6) Parking brake cables – OEM, #46420-12550 and #46430-12450, (2 @ $58) Techna-Fit steel-braided hose kit, #TOY-2200, $95 |
#3 |
I helped enviri do a complete rear disc conversion on his Yaris liftback. He purchased a complete rear axle assembly with the brakes and ebrake cables attached from Japan off a Vitz RS. We did some comparisons of his existing axle and the RS one, and noticed that for the axle the only real difference was the metal plate at the end of the axle, which the hub bolts to. On the RS one the plate had an extra ear to bolt the rear caliper frame to, whereas the drum brake axle lacked that mounting point. So, to do the conversion with OEM rear disc brakes, you really need the rear axle as well.
As for the ABS, the sensors are pressed into the rear hub, so you would need a rear axle already setup for ABS (as the one that he purchased was).
#4 |
ebay: complete assembly - $400-750
OR 2012 rear disc hub assembly + custom hubspacer/mount + parking brake line |
#5 |
![]() ![]() ![]() Drives: 08Yaris2D, 88LandCruiser. Join Date: Jan 2013
Complete waste of money, as the rear brakes on a yaris have very little effect on braking performance.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
#6 |
^ if you want to proportion the brakes so the rears do more work, or because you do car shows and want the mod points, it's NOT a complete waste of money.
#7 | |
#8 |
My opinion covers why anyone might want to do it. I run drum brakes in the back, just like you. My opinon therefore was NOT for me, as you state.
Yours was that it's a waste of money, period. Glad we are clear there.
#9 |
just gotta try it out in person first...or let me be the only person in the US with OEM rear setup...lol
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| Yaris rear disc brake conversion kit - Australia sellers?? | defecta | Australia | 2 | 10-28-2010 04:05 AM |
| For those who have the rear disc brake conversion | mrbond | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 06-05-2009 04:01 PM |
