![]() Drives: Yaris Ascent 2015 Join Date: Aug 2018
My Yaris is 3 years old. For the last two years I have heard a loud rattle sound, usually on a slight incline and around 2-4000rpm.
The dealership have ‘investigated’ but are continually unable to locate the noise. It is difficult to pinpoint the location of the sound. It’s potentially from the other side of the driver’s footwell or coming from low down within the centre console. Is this common ? How have others rectified this? |
Probably a loose exhaust shield vibrating against something, a fairly common issue with these cars. If so its nothing to worry about. Crawl under the car and investigate. You should be able to bend / adjust the shield so that it is not hitting anything.
Thanks NYC
| Tags |
| acceleration, noise, rattles |
| RATTLING NOISE EXHAUST PIPE/BACK OF ENGINE | joeljcruz86 | DIY / Maintenance / Service | 15 | 09-13-2014 07:46 PM |
| Various problems with service at shop (green coolant and accelerator rattling noise) | LilyOfTheYaris | DIY / Maintenance / Service | 4 | 04-08-2014 11:31 PM |
| bearing noise from 3000rpm | yemfoo | DIY / Maintenance / Service | 2 | 09-28-2012 03:09 PM |
| AC makes a rattling noise when turned on. | gabriel2012 | DIY / Maintenance / Service | 8 | 07-12-2011 07:03 PM |
| annoyin noise (ticking or rattling) on idle.. | abdallah380 | DIY / Maintenance / Service | 2 | 04-18-2009 06:40 PM |
