Old 08-06-2018, 02:07 PM   #1
Pinchlite
Drives: 2007 yaris HB
I can remove the spacers if need be.Thanks for the heads up though.
Old 08-06-2018, 02:10 PM   #2
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
You're probably going to have to depending on how/where you drive.
Great looking car overall. The sunroof wasn't factory, was it?
On Instagram
On Wheelwell
Old 08-06-2018, 03:07 PM   #3
Pinchlite
The sunroof is a webasto and pro installed.600.00CAD all in.
currently running 40 or 42 offset 205/50R16.Rear fenders are shaved and only rub slightly over highway dips.30mm spacers rear and 10mm up front.
Once on the teins,depending how the fitment is I may remove the rear 30 and replace with the 10.
Too bad its not worth/cant run a stretched tire.7inch rims are not wide enough.
Old 08-11-2018, 10:54 AM   #4
Pinchlite
Well I got them on but not near what I want.Same exact same as the manzos.
Going to get tein coilovers.Bottom line is manzos offer the same drop at nearly half the price.
Can an aftermarket part void my car warranty? KCALB SIRAY General Yaris / Vitz Discussion 7 05-26-2022 11:47 AM
3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation keiri Third Gen Yaris General Discussion 26 09-04-2020 01:01 AM
Part number Spellino DIY / Maintenance / Service 3 01-15-2018 01:31 PM
AFE Intake part - were to locate Darwin84020 Performance Modifications 1 03-26-2017 05:35 PM
Evap canister part number for 2007 yaris sedan baseballfan416 DIY / Maintenance / Service 4 04-26-2015 12:16 AM
