Old 12-09-2017, 03:20 AM   #1
Spellino
Drives: Toyota Yaris 2007 Sedan
Part number
So what is this part number and how does it work with part replacement. I own a 2007 Yaris sedan and I'm looking to replace the upstream O2 sensor. I got one off AliExpress which I promptly contacted the seller for compatibility. He asked that I check if the part number corresponds.
Does this mean, even for the same model car, the parts could be different based on the number of a particular part. I don't get it. If I bought a part meant for the Yaris, is it not universal?
Spellino is offline   Reply With Quote
Old 12-10-2017, 09:12 PM   #2
YarTed
Drives: 2015 Yaris 5Dr
Hi Spellino, On the website that you bought the O2 sensor on, it probably had a list of the Toyota original equipment part numbers that it corresponded to. ( O2 sensors are usually 10 digits, starting with 89465-XXXXX or 89467-XXXXX . So you will need to find out what the Toyota part number would be for your vehicle. Then check the list. ( Different countries have different emission standards and their are also various engines and trans for different countries. So one switch will not fit all 07 Yaris. Good luck
YarTed is offline   Reply With Quote
Old 12-12-2017, 08:53 PM   #3
M4One
Drives: 2007 Toyota Yaris Hatchback
Try this site to find the part number. Enter your vin. http://www.toyodiy.com/parts/
M4One is offline   Reply With Quote
Old 01-15-2018, 12:31 PM   #4
Spellino
Thank you
Oil filter part number Kitt DIY / Maintenance / Service 7 03-11-2019 08:37 AM
2006 Yaris: Rear Badge Part Number? hasher22 Cosmetic Modifications (Exterior/Interior) 2 07-16-2017 05:23 AM
Part Number Help Supra_Yaris DIY / Maintenance / Service 2 08-09-2016 01:42 PM
Part number ID, if possible NEexpat DIY / Maintenance / Service 2 05-21-2014 05:39 PM
HELP: JDM Armrest Console Box part number GabL Cosmetic Modifications (Exterior/Interior) 7 10-24-2006 11:12 PM
