Old 08-25-2018, 08:54 AM   #1
Pinchlite
Drives: 2007 yaris HB
My top pins were rusted on the top part underneath the boots.I did not notice wear though compared to the new.I replaced boots and sprayed lots of brake cleaner into slider pin tubes and cleaned out with screw driver and rags.Rotors were changed aswell.I was going to do the piston repair kit but decided not to.Brakes feel much better know.
(I think it's amplified through the suspension)
For sure because it sounded like something larger,or suspension/steering related.
Pinchlite is offline   Reply With Quote
Old 08-25-2018, 12:23 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Did you manage to get the little rubber rings on the caliper pin inserted past the new boot? Despite trying to really seat the boots into the caliper bracket, I couldn't get the pin with the rubber ring back in without tearing the rubber ring. Open to any suggestions as to how to get those rings in without tearing them.
Old 08-25-2018, 01:24 PM   #3
Pinchlite
Those o rings were easy to put onto pin and insert into caliper.Not sure if I understand?
The rubber boot had nothing to do with O rings.
Old 08-25-2018, 04:36 PM   #4
06YarisRS
Yes, it's easy to put the rings on the pin, but I couldn't get the pin to slide in through the new boots once installed them onto the bracket. It's as if the boot lip wouldn't fit fully into the channel in the caliper bracket therefore not creating a completely round hole through which to push the pin.
The front brake upgrade thread - just the facts brushforhire DIY / Maintenance / Service 35 04-07-2022 07:07 AM
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
Would these front suspension parts be any good? Pinchlite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 02-09-2017 10:07 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Front bra for S model Sedan? N9QGS DIY / Maintenance / Service 2 06-27-2009 08:51 PM
