Old 05-19-2016, 01:49 PM   #1
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
The front brake upgrade thread - just the facts
Okay so along with my engine swap, I also upgraded my front brakes.
[Picture coming]
Edit: You will not be able to use anything smaller than a 15" rim if you do this!! Still gotta check to see if the 15" steel rim will clear. I am thinking it should.
I first saw this done in Enviri's thread. I figured I would make an official post about this so newcomers can see a quick good options for upgrades, for cheap.
Our cars don't need a ton of braking power, but a little more will never hurt.
Big brake kits are $$$$ and can be counterproductive for our cars. We really don't want a lot more rotational weight. It can be tough to fit wheels. Cost.
Using the Yaris SE front rotors and calipers from a xD/Corolla are perfect upgrade.
It takes us from 255mm to 275mm.
A bit more surface area to grab, and slightly bigger rotor and caliper also really fills out the wheel nicely.
Pics courtesy of Enviri:
So here is the parts list:
Yaris SE front rotors: 43512-52130 x2 (I used OEM, I don't think I found A/M of these)
Corolla/xD Caliper RH: 47730-12A10 (I used cardone 19-B3435)
Corolla/xD Caliper LH: 47750-12A10 (I used cardone 19-B3434)
Pads: 04465-02220 (xD number, corolla use a different pn I believe, but will work also. I used Magneti Marelli from my work. They are $76.00 and come with all the hardware. Work awesome, too.)
Enviri used Hawk pads (HB627 Z.690 - made for Scion xB/xD & 09+ Toyota Corolla / Matrix / Rav4)
Brake fluid.
So if you shop right you can probably do this for around $500. I waited until I really needed brake to help justify the costs, since I was gonna buy pads and rotors anyways.
That is it as far as base needs.
Here are parts I recommend to get the most out of this. (Really not a bad idea, for longevity and if you vehicle has lots of miles.)
Stainless steel braided lines. I bought mine from Microimage. A good idea if your vehicle has a lot of miles. I live in PA so the winters are rough here to. Replacing the old rubber lines is never a bad idea. Fronts for about $60. Full set for about $120. I did the rears at the same times since I was already making a mess.
The other thing I would recommend would be some good caliper paint. I used G2 system, from Tirerack. It is a two part epoxy paint, and it is fantastic. Much easier to do now, before everything is installed. About $40 shipped. Worth the looks and protection, IMHO.
Please excuse my messiness. I also coated the rotor hats, and edges.
So here comes the best part. These bolt right on.
Tool list:
Rachet and sockets.
Sockets: [double checking sizes]
Wrench: 8mm for the bleeders
Breaker bar will be useful
Possibly a 1/2" impact to loosen the caliper bolts
Towels
Catch container for brake fluids
Just take off your old calipers, pads, rotors and put these on.
Whether you just replace front calipers, or do braided lines the whole way around, you will need to bleed the brakes.
If you just did calipers, then start with the passenger side when you bleed them
If you did lines the whole way around start with the passenger rear, then the drivers rear, passenger front, and finally the drivers front. I went around again just for good measure.
How to bleed brakes:
You will need another person to help with this. You will have the person in the car pump the brake pedal up and hold it while you crack open the bleeder. Once fluid slows down coming out, then you close the bleeder. Repeat this until the fluid comes out without bubbles, before moving onto the next bleeder.
My bleeders were 8mm. I recommend a wrench here for ease of quick opening and closing.
Weight comparison courtesy of Enviri:
Yaris rotor 8lbs
Yaris SE rotor 10lbs
Yaris caliper 13lbs
Corolla caliper 15lbs
So for rotating mass there's a 4lbs increase and in overall car weight its 8lbs
[more updates and pictures coming]
brushforhire is offline   Reply With Quote
Old 05-19-2016, 05:27 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Well, now I've got more things to take off of the Corolla when I go 2ZR-swap shopping...
Old 05-20-2016, 12:08 AM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Great that you shared this. I am thinking this will be a worthy upgrade with the new speeds I should be hitting. It will be critical with the shorter shutdowns at the Texas/Arkansas/Colorado Mile venues, etc.
Sent from m-o-b-i-l-e
Old 05-20-2016, 07:47 PM   #4
NJP440
2010EGGHATCH
NJP440's Avatar
Drives: White 2010 Yaris Hatch
Very useful info! I shall invest in this once my turbo install is complete.
Sent from my SM-G920T using Tapatalk
IG: 2010EGGHATCH
NJP440 is offline   Reply With Quote
Old 05-21-2016, 05:22 AM   #5
rabbito
rabbito's Avatar
great info yo
Sent from my SM-J700F using Tapatalk
Cosmetic: Toyota red emblem
Old 05-21-2016, 11:19 AM   #6
KTS
KTS's Avatar
Drives: Vitz RS
Great info and a nice upgrade.
From the picture comparison this upgrade for the yaris seems like it's the stock brakes on my JDM 2007 Vitz RS. I could be wrong thou.
KTS is offline   Reply With Quote
Old 05-21-2016, 12:47 PM   #7
brushforhire
It is possible that it is the same, since it does use the Yaris SE front rotors. I would imagine that the Vitz RS probably uses the same rotors. I would be curious about your brake pad size.
Project so far: 2zrfe swap, Megan racing coilovers, TRD rear sway bar, whiteline bushings, RPM long tube header, midpipe, and DC sports xD exhaust, brake upgrade in front, MI stainless braided lines all around, matte paintjob, Takada cold air intake, various gauges, rear seat and belts removed.
Future: Turbo.
Old 05-21-2016, 01:44 PM   #8
KTS
KTS's Avatar
Drives: Vitz RS
The Vitz RS pad is about 4-5 mm taller than the yaris pads.
Old 05-21-2016, 07:51 PM   #9
brushforhire
Thank you for this!
Here are dimensions of the Hawk pads for the xD
Here are dimensions for the Yaris hawk pads.
Future: Turbo.
Old 05-24-2016, 09:18 AM   #10
Quick Q: are 15" the smallest diameter rim you can fit with this brake upgrade? Or will 14" still fit?
Old 05-24-2016, 09:33 AM   #11
If 14s just fit over the stock brakes, then 15s are probably the smallest that'll fit over the bigger brakes.
Old 05-24-2016, 11:23 AM   #12
enviri
enviri's Avatar
Drives: 2010 Yaris
15" will be the smallest you'll fit over the bigger brakes.
Old 10-05-2016, 12:46 PM   #13
enviri
enviri's Avatar
Drives: 2010 Yaris
just a FYI: tire rack currently (as of oct 5 2016) has a special on hawk performance pads for this BBK for $40 off regular price.
http://www.tirerack.com/brakes/brake...0&autoModClar=
Old 10-19-2016, 05:20 PM   #14
Don't want to revivie an old thread, but figured I'd rather keep the facts for this on this thread.
What year Yaris SE are the oem rotors from?
I'm due for new rotors and pads next summer and figured if I can get everything off of rock auto it'd be worth it and cheaper than what the OP quoted.
I found Yaris SE (2012) A/M rotors for just over $20 each but I can't find a proper part# nor a dimension shoing if it is 275mm OD or not
Old 10-24-2016, 09:53 PM   #15
Yargh-Is
Drives: 2009 Yaris HB
Hello Yaris enthusiasts, anyone happen to know if the Yaris SE rotors (275mm) come slotted and drilled? I cannot seem to find them using the Yaris SE pn: 43512-52130.
Appreciate the help!
Yargh-Is is offline   Reply With Quote
Old 10-25-2016, 04:46 PM   #16
enviri
enviri's Avatar
Drives: 2010 Yaris
all yaris SE is 275 front. MUST BE FROM SE model only.
43512-52130 is not drilled or slotted.
Old 11-14-2016, 06:38 PM   #17
JessMess
Drives: 08 Yaris hatch back
quick question
"Using the Yaris SE front rotors and calipers from a xD/Corolla are perfect upgrade."
What years for the Yaris SE? And what years for the Xd and Carolla?
I work at a Junkyard and we can only look up cars by the year and not a part number
JessMess is offline   Reply With Quote
Old 11-14-2016, 08:47 PM   #18
enviri
enviri's Avatar
Drives: 2010 Yaris
Scion XD/09 Corolla/Matrix Calipers USED: ~100$ off ebay; ~165$ on rock auto (semi-loaded caliper)
(toyo part# 47730‑12A10|47731‑12A10
06/2007-06/2014 SCION XD ZSP110
12/2007-07/2013 TOYOTA COROLLA ZRE142
2012+ Yaris SE rotors (toyota part# 43512-52130): ~105$ ea (msrp)
Time to replace rotors. Which brake upgrades? BennyLava DIY / Maintenance / Service 25 05-16-2016 05:57 PM
Problem removing front brake rotor jkuchta DIY / Maintenance / Service 24 02-27-2016 09:41 PM
Bolt Thread Size 4 Brake Drum Removal BobTheYaris DIY / Maintenance / Service 5 08-17-2014 01:14 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
