![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Those o rings were easy to put onto pin and insert into caliper.Not sure if I understand?
The rubber boot had nothing to do with O rings. |
Yes, it's easy to put the rings on the pin, but I couldn't get the pin to slide in through the new boots once installed them onto the bracket. It's as if the boot lip wouldn't fit fully into the channel in the caliper bracket therefore not creating a completely round hole through which to push the pin.
| The front brake upgrade thread - just the facts | brushforhire | DIY / Maintenance / Service | 35 | 04-07-2022 07:07 AM |
| Yaris Sedan Deadening and Sound system upgrade | derickveliz2 | In Car Entertainment + Electronics (audio / video / alarm) | 2992 | 11-18-2021 02:14 AM |
| Would these front suspension parts be any good? | Pinchlite | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 02-09-2017 10:07 PM |
| Newly refreshed 2011 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 23 | 11-27-2010 12:57 PM |
| Front bra for S model Sedan? | N9QGS | DIY / Maintenance / Service | 2 | 06-27-2009 08:51 PM |
