Old 08-25-2018, 04:17 PM   #1
tmontague
tmontague's Avatar
I just go sans o ring as it always jammed up when i woukd inspect my sliders which I do every month due to track sessions.
Wire wheel off any rust or replace completely if they at pitted and use a good quality rubber safe high temp grease. Checking the sliders every 6 months is what I found was best as they seems to become contaminated fast on the yaris
Old 08-25-2018, 04:39 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Next time I clean the pins, I'll try again with the little rings. If it gives me any grief, in they'll go without the little rubber ringies.
The front brake upgrade thread - just the facts brushforhire DIY / Maintenance / Service 35 04-07-2022 07:07 AM
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
Would these front suspension parts be any good? Pinchlite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 02-09-2017 10:07 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Front bra for S model Sedan? N9QGS DIY / Maintenance / Service 2 06-27-2009 08:51 PM
